Generator Hazards and Inspection
by Nick Gromicko and Elise London
Homeowners may use a generator to supply electricity to their home in the case of a power outage, either out of necessity or convenience. Inspectors may want to know about generators and the potential hazards they present when improperly wired or utilized.
Generator Types
There are two main types of generators:  permanently installed, standby generators; and gasoline-powered, portable generators.
Standby Generators
Standby generators typically operate on natural gas or liquid propane. They remain fixed in place outside the home and are designed to supply on-site power to specified circuits through a home's electrical wiring. These generators work in tandem with a manual or automatic transfer switch, which automatically detects an interruption in grid-powered electricity and subsequently transfers Standby generators are non-portable and may require a permit.over electrical input to the generator. The transfer switch suspends input from the generator once it senses that utility-powered electricity has resumed. Generators for small- to medium-size homes are typically air-cooled and employ fans to regulate the temperature inside the unit. Liquid-cooled units are used for the larger energy loads in larger homes.
Some advantages of standby generators are as follows:
Disadvantages of standby generators are as follows:
Portable Generators
Gasoline-powered, portable generators are typically smaller in size and power capacity than permanently installed generators. They are designed so that corded electrical devices may be plugged directly into them.
Advantages to portable generators are as follows:
Disadvantages of portable generators:
Hazards
Inspection
InterNACHI inspectors may want to check for the following:
In summary, generators can be lifesavers during a power outage, but they present serious health and safety concerns if they are not installed and used properly.
InspectorSeek.com
Take InterNACH's free, online How to Perform Residential Electrical Inspections course.
Carbon Monoxide Poisoning and Detectors
Inspectopedia
